VincentRapide
- Jun 23, 2020
- 30
Manufacturer warns against handling these panels by one man, but I am what I am Also I have a 17ft assistant (forklift) that could help lift these panels off the trailer where they are stacked. So first decision is to always keep the panel in Landscape Mode with a separate sling at each end just as if there was a crew of 2 men. To stabilize this I'm thinking to use a 6ft 4x4 crossbar with the 2 slings hanging near each end and the forklift lifting at the center. Ratchet straps hung on large eye hooks at either end of the crossbar - large enough to allow the nylon to slide thru only when pulled and not by gravity alone. We want this to be a safe journey from stack to ground mount.!!
Hope this makes sense.
__
__
