I have a small system in my shed. I bought a new Power Queen 12v 200ah selfheating lifpo4 batt to use this winter. I built a insulated box for it. My original batts are Power Queen 12v 100ah selfheating connected in paraell. I'm using a Power Queen charge controller, and a Renogy 12v 2000watt inverter.
All this worked very well since April of this year, no problems at all.
The problem is the new battery. When I try to connect it to the inverter the voltage drops to 8 volts then 0 volts. The bms is cutting it off.
The capacitors in the inverter are retaining 4v or so when it's disconnected. This seems to be causing my new batt to shut down.
I dont understand why?
I think the bms is bad in the new battery, maybe.?
I have switched back to the old batteries 3 times already and they work.
Thoughts, ideas, suggestions how to get my new batt hooked up and working or prove the bms is bad.
Yes, I'm spoiled now, I love having electric in my shed, I need it to work.
