Hey all, new to this and my 1st post.
I’m completely off grid in Canada running a 20kW generator to charge and 9kW of solar panels. I’ve installed 2 x 15kW Sol Ark inverters in parallel and have also installed Narada pb-C VLRA battery bank x 3 in parallel , 2v 600aH x 24. So 48v 1800aH total.
I’ve ran this system in the summer using batt V setting with no real issues. During this winter I’ve had to adjust set points so often due to loads and temp fluctuations that I’ve switched to batt%. I’m trying to get it to operate at 100% charge and drain to 70% then turn on generator to recharge back to 100%. It will only charge to 98% and will continue to drain to 70% and generator will start charging.
However the voltages will drop every charge cycle by a .2v or so. My float is 53.9v. My absorption and equalization is 55.2. My battery empty is 43v. The system has dropped from 72% to 0% then it will charge batteries back up to 56.8v. Runs good for a few days and then drops off again from 72% to 0%, and volt drops by about .2v/charge cycle and repeats this cycle.
Any advice would be greatly appreciated.
