Hello. Just ordered AC200P.
Roxie60
Now looking at accessories. Unfortunately the AC brick is out of stock. No idea when will be available. Also considering the 120w panels but even on sale that is a wad of cash for 240w (especially since 2 required to meet that VoC minimum.
Anyone found an acceptable panels(rigid or folding) alternative that has decent price, correct connectors and voltage? Or do you think the Maxoak panels can't be beat.
Looking forward to sharing experiences.
The best value is used solar panels. Check your local Craig’s List. Sometimes there are new panels there because someone will fill up the pallet - then sell the extras.
suntansolar. Com sells used ones.
Agreed, this is the first place to look.
Roxie60, roughly where are you located? It just takes a minute to see what big cheap panels are nearest to you.
Its very common to find new panels for $.50/watt. The only trick is knowing your charge limiting factors (usually max input voltage) and checking specs of available panels.
Central IL
