Hi Guys,
I have a 16s 280A Battery Pack build in a ESS Case with Seplos BMS and EVE LF280K cells.
THere is also an active balancer connected from QCC
The cells are fixed in the case
All where successfully charged to 3,45 V.
The day after i as i tried to built in the pack to my vessel i had to dismount some cells to make the pack lighter.
As i removed the screws from fixture which was quiet hart the 2 of the cells expanded dramatically they get 1,5 cm thicker!
i even could not get them out of the case, because they were so tight.
to get them out without any violence, i reconnected the cells again so that i can make a discharge with my inverter in the hope the swelling goes a bit back.
as i checked voltages in bms i saw that two cells hat 3,9 V. at this moment the discharging was running for about 1-2 mins. so in this case i assume the voltage was before discharging above 4 or maybe 5V.
So how can this happen wihout any charge connected.
Can this be caused by the active balancer?
Or can cell voltage rise due an damaged cell by itself?
