Stainless03
Hurricane season is upon us in South Florida and I've convinced myself I need to build another run of the mill "portable" power station. But the more I read the more confused I get. I need a unit that will start up 12,000 btu stand up A/C unit, two refrigerators, and phone/laptop chargers overnight. The A/C requires 1100 running watts and I'll need roughly another 1000 watts for the other items. I began looking at the LV6548 style inverters or the 3k EG4 unit but they don't seem to have the required surge capacity to start an A/C that size. So at this point I've been looking at the Multiplus II 48/3000 or 48/5000. I know the 3kva will run 2400 watts constant which is enough, but will it have the surge capacity I need? Is there another inverter I should consider?
Currently I plan to charge the unit off of my 4500 watt(3500 constant) inverter generator during the day when needed, but down the road I'll add small amounts of solar. I expected to need two EG4 server rack 48v 5kwh batteries knowing that A/C uses an easy 1.1kw per hour. In the future I will likely use it as a UPS for a freezer or take it to my office to run computers/registers when the power goes out there.
And just out of curiosity.. How large of an inverter would I need to power up my 120v 2hp air compressor? My generator will start the motor with no load, but if there is pressure in the tank I have to be plugged into my washer outlet in the house. That's not a need, but it would be cool to have a plug in the garage that actually works for the compressor.(I have no intentions of staying at this house long term, so I'm not wasting money having it all wired right.)
Thanks guys!
Thanks guys!
