Gadget.26
Hi all
I have a catering van. Currently using a generator to run it which costs me around 10-15 pounds a day. I run around max to max 2.5kva so looking to go batteries but want to run 3kva not that I’m probably guna anywere near that every day but just want to be in safe side in case I add extras later on down the line.
I have a fuse board in the back of the van. Can I stick an inverter in the back of the van or is it dangerous as I have gass bottles in the back. It it fire boarded off.
Also what inverter and batteries etc will I need to run a 3kva set up ? And will be be better to connect the battery to original battery ? Or direct to my alternator
Thanks zaf
Thanks zaf
