greeksolar
Hello,
I have a farm and large property in Northern Greece. At the moment we have 3 phase grid power, and a 50 KVA generator on a transfer switch, which gets used a lot since the grid is very unstable in our particular area.
I am in the process of specifying a system and was hoping for some suggestions and advice since you folks have experience, and its better to get the right stuff now rather than fix the wrong install later.
20 KW in panels, 550W mono panels, Mounted on a flat roof with NO SHADING around
A hybrid MPPT inverter
50 kwh of Lifepo4 batteries
We can NOT Net Meter, but we CAN connect to grid to consume power. .
BUT, though we have 3 phase service, usually one phase is down.
we consume about 40-80 kwh a day.
Electricity has gone up 400% here in the last year, its almost a US DOLLAR PER KWH (yep, nuts).
Most of our loads are single phase, except 2 large heat pumps, and the Electric vehicle charging station, which are 3 phase.
We can't go totally off grid as we would need huge 150-200 kwh batteries, expensive, and need lots of space.
So we need to design a system that can charge as much as possible during overcast/cloudy days.
And we also need to be able to charge our batteries from just a single phase from the Grid.
Its kind of a tricky situation, and hoping you experienced ladies and gentlemen can help give me some advice and solutions.
thank you!
thank you!
