Highlandergymn
- Dec 10, 2019
- 6
I have two 120 watt panels and a Victron 100/50 and 100/30 charge controllers. I've switched around the controllers and the panels and get the same results. The wire going into the controllers shows 22 volts and zero volts according to the victron software. If I run the panels in series together I get 44 volts and still zero in the software. I have a battery hooked up and the software sees it. I hooked up the battery first. Any ideas. Hard to imagine both panels are bad and both charge controllers.
