Chickenbone
- Apr 15, 2020
- 3
Hello
I have 4 LG Chem 10s 36v 6kWh 60Ah and I plan on putting the 4 in parallel for 24kWh. I've been looking in to Baly BMSs but not committed.
I'm asking what BMS would you get for this setup?
Thank you. I appreciate your time.
More specs
Max charge full voltage 4.2V
Discharge cut-off voltage 2.8V
Standard charge and discharge current
CC charge 1.0C/60Ah,cutoff voltage
4.20V,Capacity>60Ah
Max continuous discharge current 180A(3c)
Weight About 0.88±0.02Kg
Internal
Impedance(Max, at 1000Hz)
≤1.5mΩ
Standard Charge method
0.5C CC charge to 4.2V, 4.2V CV charge to 0.02C cut-off
More specs
4.20V,Capacity>60Ah
Internal
≤1.5mΩ
