Hi team,
I have a solar system with Deye Hybrid Inverter. I think my system is just similar to this diagram which is showing on Deye display panel:
![1688233227755.png 1688233227755.png](https://diysolarforum.com/data/attachments/155/155310-254c0f6d22340ef31cd2f4a726ee2e38.jpg)
To describe, I'm using solar as primary power source (day time) and grid to supply loads in my house. Battery is installed to activate inverter if grid is down during daytime, or to run some basic appliances if grid is down during nighttime.
However, I'm not sure if there is a setting to allow this behavior during night time:
-If grid power is available, grid will be used as power source between 18:00 to 3:00, during this time, battery SOC is 100%. From 3:00 to 5:00, battery will discharge to 20%.
-If grid power is cut, for example, at 22:00, then battery will discharge immediately at 22:00 and will be used until it reaches 0%, then my loads are off.
Can you help?
Can you help?
