brooke_heaton
- Sep 28, 2020
- 31
Hey folks, total nube here. I am working on outfitting my 2018 Aliner Ranger with a solar setup and large storage capacity for boondocking. I was able to grab two lightly used Valence U27 XPs (138AH) for a total of ~276AH in a 12V parallel setup. With this setup, I plan to use the Xantrex Freedom XC 2000 80Amp 120V inverter/controller which has a 2000W capacity and 4000W 2-second surge. It's generously large because my popup has a 120V AC unit and compressor fridge and I'd love to be able to go 5-7 days boondocking using solar (solar is in planning stages). I plan to use the Thunderstruck BMS for Valence U27s for HVC/LVC and HTC/LTC.
I have a few questions:
- Would the inverter/controller be able to detect high/low voltage and cutoff to protect the battery? And if so, is that even a concern since I'll have the Valence BMS?
- Should I use a battery protect on the 12V side? Or is that not compatible with the inverter?
- Is it necessary to add a shunt to this to monitor the batteries? Or is that overkill?
- What fuse should I be placing on the 12V side, which will have smaller loads but maybe up to 100amps?
- Is a surge protector necessary on the charger? I've seen some people mention surge protection and since I'll be at campsites/outdoors, maybe that's a good idea?
