Although there does not seem to be a consensus on what the dividing line is at it seems that low voltage are the typical panels for many of us. With the panels Voc being in the 20-40Voc range. Higher Voc panels have been mostly used in grid tie setups. Many of these are 60Voc and higher. I was just looking at some that boasted a 99.4Voc. There are benefits and efficiencies to having the higher voltage as well as issues.
It got me thinking when I read that higher voltage panels can handle shading better if someone should source them over more easily found low voltage panels. Now that higher voltage MPPT SCC AIO's are more common I could see where having higher voltage panels might simplify array setups.
Are there any out there are running high voltage panels in a Off Grid setup? What do you think of them? Are they worth the higher initial cost?
