Erible
- Sep 24, 2019
- 2
Seems like it's common for people to run their inverter and fuse block through the same breaker to save on wiring. Will does it in one of his videos and I'm just trying to understand the setup. Here are the questions I have:
1. In Will's video, the Inverter and fuse block have the same rating; 125A. What if your fuse block and inverter have different amp ratings? Would it be best to have separate fuses or to just use a fuse for the one with a lower rating?
2. If your inverter and fuse block are EACH pulling 125A wouldn't that mean that you're pulling 250A through the shared fuse and you can blow it easier?
