First up is an energy audit / totals....
I am trying to power 1500 sq feet with 2 window units,
Traditional window units? Say 1000w each running 50% (on/off) = 500w x 24hr = 12kwh each.
24k wh/day
2 fridges, 1 deep freeze, '
Let's guess 4 kwh/day.
TV, a few lights and internet during hurricane power outages etc......
Let's guess 2 kwh/day
and may bump up to day time use but that is later.....this would require running a couple more inverters, more panels and a larger battery system but for now I am looking to purchase
Grand total guess = 30kwh/day.
10 panels and a 48 volt battery as I already have the inverter listed. All parts bought through the website provided by Will.
10 of these
https://signaturesolar.com/renesola-solar-370w-mono-solar-panel-silver/ are these enough to recharge a 48 volt lithium battery ?
10 x 370w = 3,700w PV system. You don't say you're location - you can use PVWatts to get a good idea -
https://pvwatts.nrel.gov/pvwatts.php.
If I extrapolate from my own system, 3.7kw PV array will produce ~ 5,220kwh/year.
5,220kwh/year = 14kwh/day 'on average'. Depending on your location - summer can be 4 x more power than winter.
In rough numbers then, you need 30 panels rather than 10.
However, if you replace window units with heat-pump and get that 24kwh/day down to 10kwh/day - then you need 20panels instead of 10 'kind of thing'. At 20 panels you'll need ~ 20kwh battery for off-grid to run things thru the night.
Plenty of AC power for the loads listed.
https://sungoldpower.com/collection...erter-parallel-wifi-monitor?sscid=51k6_2tnpw&
with a 48 volt battery system - I have not chosen one yet, anyone using a solid state battery system?
Solid state doesn't exist yet for home powerwalls. More like iPhone charger level at this time.
It shows I can run 2 solar arrays and wasn't sure if running 2 5 panel arrays or just one 10? THANKS!!!
Yes you can have 2 arrays but it's not about panels it's about max voltage and max power.
The Unit specs (from your link above) say
1) Max PV Array Open Circuit Voltage = 250vdc. This means you can do up to 4 panels in series ~ 200v leaving room for low temp variance.
2) Max Power = 4000w per input. This means you can do 10-11 panels per side.
2a) 2s5p on each array would be 3700w each. At 2s the MPPT voltage will likely be 60-80v - high enough for a 48v battery.
2b) If you do 3s then 3s3p (9 panels) then overall voltage will be fine but it's only 9 panels (3,330) instead of 10 in 2a option.
2c) If you do 3s4p (12 panels) then overall voltage will be fine but it's 4,440w (on a 4,000w max) and it might be OK as long as you don't get 100% power from the panels
2d) If you go down to 330w panels then 3s4p (12 panels) would be 3960w - voltage would be great and you'd be right at 4000w.
*I'd recommend 2d.....
