keeperofthecode
Building a new house and I'm trying to decide how many solar panels I should get. My system will be 2 x EG4 6000xp connected to a single Power Pro battery. System will be running everything in my house excluding AC, washer & dryer (Stove and water heater are gas). It's a new house build so I really have no idea how much power will be used but I feel like it will not take much power to run everything since it's more or less powering my energy vampires, ceiling fans, lights, TVs, camera system & network equipment. I'm thinking go with the Talesun 400W Bifacial Solar Panels. Minimum order is 10 panels so I'm thinking about ordering 12 panels and running a string of 6 to each inverter. Will recommended a voltage of at least 200 since the mppt minimum is 120 so 6 x 37 VOC would be 222 with a wattage of 2400 going to each inverter. Is the way I'm doing it the best or should I just run all 12 in series to one inverter? I'm a bit confused if I should split it across the inverters or if running to just one is basically the same thing.
