kolek
Inventor of the Electron
- Sep 29, 2021
- 1,123
Hey guys, in the event the AIO inverter fails for whatever reason, I don't want to rewire the grid to loads panel connection from scratch.
So I'm trying to figure out the best way to switch the grid connection between the loads panel and the AIO inverter. Basically, if the AIO inverter fails, I want to flip a switch and be back to running the way I was before I installed the inverter.
I was thinking I could use a transfer switch to switch the grid between the inverter and the loads panel. But that would mean I need to always remember to manually turn switch off the connection shown in red in the attached picture, which is the load output from the inverter to the loads panel. Or it is not necessary to switch that off? If I don't switch it off, it would mean the grid can run directly into the AIO load output, assuming this circuit design.
(Sorry for the primitive circuit diagram)
Any suggestions for how to do this in a more idiot-proof way?
Thanks in advance for any tips.
