I want to preface this by stating that I’m brand new to anything solar and electrical so I appreciate any help with my questions. And forgive my ignorance in a lot of this.
Paying up to $0.50/KWh at peak times in my area was getting stupid expensive so I wanted to create a small off-grid system as a sort of proof of concept before building something bigger to try to lower bills.
I put together a EG4 6000ex and 2 LifePower4 batteries with 9 locally-sourced used 208W solar panels ($25 each.. decent deal right?). Output from the inverter is being fed through a separate 100A main AC panel--probably overkill I know. But I wanted to be able to use the main breaker as a sort of on/off switch when I’m not using the system. So far through the AC panel, I’m able to L2 charge a PHEV, run appliances (oven, fridge), and run various electronics—such as multiple TVs, computers, etc. I haven’t tried to max out capacity and run everything at the same time yet.
Here are my questions:
- How do I properly ground this setup? I’ve watched Will’s videos regarding grounding on his setups but I’m still confused. My setup is completely off grid so no AC input connection. I have ground and neutrals separate in the AC panel. Am I supposed to create a N/G bond in there? I’m assuming there’s already a N/G bond in the inverter. Unless I’m using it wrong, my voltmeter confirmed there’s charge on the ground.
- is it common to feel some kinda small shock/current when touching an inverter's control panel? I've noticed this on a couple of mornings and its a little concerning.
- What is the best option for powering the whole house assuming I can expand my system enough to power most if not all of it? I’m currently renting the house I’m in so I don’t want to invest too much into this part of the system. The landlord has already agreed to allow me to add what is needed to run the house on solar energy. Of course, while I’m confident enough to DIY everything on my own thus far, we’ll be getting the professionals to work with anything connected to the grid.
