Any concerns with the suitcase being temporary? I would only like to deploy if needed.
On my RV I have 1650 watts of panels and setup 900 watts of ground panels. This is able to run a 15k BTU off an AC. I rarely use the RV when I need AC, so the portable panels never go out. When they do, over the day, they make more power than the roof panels.
Anything special to consider in terms of the panels, or wiring?
Nothing special for wiring. Its just running the voltage drop to see if its acceptable and then deciding whether to go in series or parallel. I don't have the SCC on the panels, I combine the panels through a combiner box and then mount the SCC in the RV. The MC4 connectors has a 30 amp limit, so I just kept panel production under that; in my case no more than 4P. With voltage loss, on a 35' homemade cable., I wanted thicker, so I butt spliced 10 AWG wire which is the thickest that goes in MC4 connectors to 6 AWG to keep the voltage loss down.
For the making the panels, my 100 watt panels are 3' X 2' unfolded, and it takes about that much panel to make 100 watts. IMO, anything bigger becomes too bulky for me to store.
Mounting with legs is something to consider. I am in 35 knot winds and there is a point before 35 knots I will lay them flat, and after that, I need to put them away or they will blow away. If I forget, I will end up walking around the site to pick them up.
Build them however you want. Because it was cheaper than I could build myself, I bought mine through WalMart and the 100 watt lion energy portable panels. They are built pretty tough. A case to store these panels in is not cheap and the WalMart ones were delivered in a box with a carrying case/
I was putting together a parts list, and was stuck on the hinge for the legs:
-2 like solar panels: 50 watt Renogy $67 X 2
--https://www.renogy.com/50-watt-12-volt-monocrystalline-solar-panel-new-edition/
-2 hinges. $2.58 (total)
--https://www.amazon.com/Global-Door-Controls-Nickel-Bearing/dp/B00164JZYQ/ref=sr_1_25?dchild=1&keywords=aluminum+hinge&qid=1614131745&sr=8-25
-4’ Aluminum Square tube ¾” $17.98
--https://www.homedepot.com/p/Everbilt-1-2-in-x-72-in-Plain-Steel-Square-Tube-with-1-16-in-Thickness-801107/204225750
-2 butterfly latches #12 $12.49
--https://www.amazon.com/uxcell-1-69-inch-SUS304-Stainless-Butterfly/dp/B07XYW9RMJ/
-Chest Handle $5.68
--https://www.amazon.com/National-Hardware-N203-760-Handle-plated/dp/B000BOAYNI/
-Aluminum Rivets 3/16” short $6.27 Home Depot
-Friction Hinge $10.20 (Not ideal, but all I found).
https://www.amazon.com/Hardware-Essentials-851584-Friction-Support-Right/dp/B00EALVLF8/
