I have a tiny battery bank to work with due to budget limitations and a stupidly power hungry inverter to pair it with. Running a tp6048 with idle consumption of 135 watts and a battery bank 48V, 60A. I'm trying to make this work with about 1750watts of solar panels., the way I see it is that the batteries at least allow me to turn on the inverter in an off-grid scenario, but aren't enough to keep the inverter powered overnight. The tp6048 goes into a low power mode when there is no solar and AC inverter is turned off. It then consumes only 25 watts. The problem is that it still thinks its getting solar during sunrise and sunset, meaning it will be consuming 135 watts between 6:30AM till about 7PM, while the array will only be generating more than that between 8AM-5PM realistically.
I don't mind the limitations, if I can only use solar between 8 and 5 that is still acceptable. The issue I am having is that the tp6048 does not have a power button, meaning it will power off due to low battery status every night. Will this damage the inverter or is it perfectly normal for an off grid inverter to shut itself down every night? I appreciate your feedback and any tips on how to make this work.
