Hi:
I top balanced by 24 LiFeP04 cells to 3.5v a few months ago, built my pack and connected the DeliGreen BMS for the first time. I have some questions about what the BMS is indicating, and I don't know if it will sort itself out or if I will have to do something. Here goes (with pictures!):
The picture shows varying voltage on cell 4 and high voltage on cell 5. Will the BMS correct this now that I have the pack connected up to the BMS?
The BMS seems to think that the cell are 30ah cells when in fact they are 78. When I try to edit I get a request for the battery manufacturer passcode. These are new Lishen cells from BatteryHookup in PA. Is there a place where I can get this code or is this a false alarm?
Should I be accepting the standard settings as presented or are there some you would recommend changing? I don't know where they are coming from to start with.
Thanks
Thanks
