G gnoeld New Member Joined Apr 11, 2022 Messages 299 Apr 11, 2022 #1 If I connect my cold water line from the water heater and run it thru a thermal panel and then back into the water heater directly and allow that to circulate will that work to pre heat my water before it goes into the water heater?
T timselectric If I can do it, you can do it. Joined Feb 5, 2022 Messages 18,572 Apr 11, 2022 #2 Yes, if the sun is shining.
R rwolfeiii New Member Joined May 31, 2022 Messages 2 May 31, 2022 #4 @gnoeld, do you already have your solar water heater panel? or thermal panel?
G gnoeld New Member Joined Apr 11, 2022 Messages 299 May 31, 2022 #5 rwolfeiii said: @gnoeld, do you already have your solar water heater panel? or thermal panel? Click to expand... No I do not
R rwolfeiii New Member Joined May 31, 2022 Messages 2 Jun 1, 2022 #6 gnoeld said: No I do not Click to expand... where are you located? I am in the Raleigh, NC area and have one being removed from my roof in the next month or so.
