2.5 years ago I built my first LiFePO4 battery. A 100AH battery using these cells:
and a JBD BMS. The battery has been great up until very recently. A few days ago I was loading up for a winter camping trip and I checked on the battery and it was totally dead according to the BMS, it was reading 0% and 12.something volts. I brought it inside to warm up and connected it to my Victron 10 amp charger. It now will only charge to 75% but is still functional but with reduced capacity. It looks like I have one cell that is spiking it's voltage early and causing charging to stop early (there's a term for this but I can't remember what it is)
up until this recent issue, the BMS always said the battery capacity was 108AH but you can see that it has it down to 75AH now. You can also see that cell #1 has a much higher voltage than the others. This battery lives a tough life rattling around in the back of my truck camper and I don't usually take it out in the winter unless it's going to be really cold for long periods of time (well below 32 fahrenheit) but I was hoping it would last a bit longer than 2.5 years.
I'm thinking I probably need to start from scratch with new cells but wanted to post here first.
1) I've got a Victron charger that has "recondition" modes, is it worth trying this to see if the cell will recover?
2) Is replacing a single cell an option? If so, does anyone know if these cells are still available? It does not look like Battery Hookup carries them anymore.
3) If I need to buy new cells, what should I be looking at? I went with these cells because they used cylindrical cells which were supposed to be more rugged and didn't require any compression. What would be good cells to use for a battery that was going to see a lot of vibration in the back of a truck camper?
Just purchased 4 BATTERY HOOKUP 3.2V 100ah MODULES
Just purchased my first LifePo4. For my first DYI project. I will update everyone on these batteries when I get them. Looks like they are hinting that they may be from the same supplier that Battle born uses...
diysolarforum.com
