D
Deleted member 9967
Guest
OK, so I am looking for a battery charger for Lifepo cells.
Specifically 280 Ah 24 volts.
Something that will not over charge them.
Preferably one I can change the top voltage on.
The amps do not have to be high.
But not below 25 amps preferably.
Preferably adjustable.
The BMS essentially only needs to monitor and allow for top balancing.
I do not need all of the other fancy stuff like low temp cut off etc as the batteries will be charging in my home.
Ok guys, I would prefer if your recommendations were ones that you use or have used.
Thank you.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thank you.
