SenileOldGit
- Oct 15, 2022
- 320
I am just setting up a pipe to go along the wall about 6 feet into my house, to my electricity meter, through which I am going to be putting meter tails for my electrician to fit to the inverter and grid input. While I'm doing this, I was thinking of putting a length of two core cable through, which I could then attach to a CT clamp in the future, if I ever want to change my inverters to export capable (I would be buying two 5kW Sunsynk Ecco inverters). I presume the CT clamp doesn't require a huge amount of power, so would speaker cable be sufficient? Once this pipe is in place (it also will have some flexible pipe at one end to get around a soil stack that the pipe has to go round the back of) it won't be possible to get any more cables through it, into the house, without removing the pipe AND all the meter tails, due to the hole in the wall of my house only being large enough to take four meter tails, an earth cable, and a 2.5mm twin and earth (for some power sockets in my inverter shed), and very little else.
I presume the CT clamp only uses two cables to connect to the inverter?
