TheGriz
More Power Scottie!!!
- Feb 17, 2020
- 128
Hello folks,
Well the four 280AH cells are ordered and shipped. So while waiting, I figure its not to soon to now investigate and order the BMS and inverter. I'm thinking 2000 watt constant/4000 watt peak pure sine wave inverter. So doing the math, 2000w/12v=166Amp. This is my first build, so my understanding is 166A would require next size up BMS or 200 amp BMS. Am I correct??? I am not made of money, so looking for quality, but don't want to overbuy. One concern I have are the leads off the BMS's I have looked at on line...the wire leads don't seem adequate for the rated amps. Thoughts on wire lead, and sizing of amps of a good BMS 4S. And link(s) to appropriate BMS.
Here is one BMS I did see that I "think" fits the bill..the 200amp version for $189. Again, thoughts?
Thank you for your anticipated insight and recommendations!
Mike
![www.ebay.com](https://i.ebayimg.com/images/g/vE8AAOSwrvtd84WK/s-l400.jpg)
4S 12V 3.2V LFP LiFePO4 Lithium Battery Protection Board BMS Balance Waterproof | eBay
◆BMS manufactured by high quality Mos and IC imported. What current BMS should I choose ?. Short Circuit protection. Over current and short circuit protection. With balance. ◆Use top quality (A-level) protective integrated circuit IC, from the solution of Seiko of Japan.
www.ebay.com
Mike
