MrNatural22
?SW sunshine =⚡️⚡️lit up thru the darkness✌️
For you helpful electricians? Question on supplying AC to a single AC outlet. I am installing shore power into my cargo trailer project to a couple AC outlets via a two 15amp breaker panel one for each outlet. I also have a 1500w pure sine inverter on board. I would like to use one of the AC outlets to supply shore or inverter power when outdoors. Can both be connected to this 1 outlet just not at the same time unless inverter is off. I know they’ll be no shared connection when Shore is not connected, only inverter.
My question is with the inverter switched off and shore plugged in will the shore power back feed into the inverter from this shared outlet causing damage?
If so should a clearly marked safety switch disconnecting the inverter be used when on shore power?
️ Or maybe a separate dedicated outlet for the inverter only?
![High voltage :zap: ⚡](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/26a1.png)
