Inverter charger set up?
cat
ottawa
I dont known the correct set up for the new inverter charger?
inverter:
Dc to ac power inverter charger for sump pump. 110 220V Pure Sine APC 6048
www.sigineer.com
www.sigineer.com
https://ca.renogy.com/48v-50ah-smart-lithium-iron-phosphate-battery/
As per the spec for the battery:
Maximum Charge/Discharge Current: 50A
Charge Voltage:54V
The closest two battery type positions on the inverter are
1 and 9
For 1
CV 56V, Float 54.8V
9
CV 50.25V, No Float
If I choose battery type 1, the battery could be overcharged.
but, if I choose battery type 9, the battery could be under charged.
what should i select? Thanks
Note: for now...all is installed and working well without charge setting on inverter (amazing to have the pump running when closing the main ?)
Option 1. Note: CV and Absorption are the same.
Your battery has a high end voltage range of 55.5 volts. That means they didn't cheapen out with 15 cells. So 56 v should be fine.
If you can, limit charging to 25a. 10a would be better.
Thanks a lot! Will try this...?
