For some reason lately when it is nice weather the inverter disconnects and reconnects.
Well there is the FLAG right there.
You didn't clarify. Is your inverter disconnecting FROM the batteries & then shutting down your AC Output ?
IF that is the case, it is your battery packs causing the issue here. I say that because you say "it is nice weather" therefore charging.
- When your battery packs reach FULL the BMS will reduce charge as resistance within the packs increases until the packs / system reaches Endamps/Tailcurrent at which point the system should switch to FLOAT mode. That is the NORMAL operation.
- Alternately, when charging IF a single cell reaches 3.650V the OVP (Over Volt Protection) kicks in and shuts off Charge altogether. When that happens the Inverter disconnects from the battery because it sees no battery voltage. Some inverter systems can continue operations with just solar power incoming and just reconnect when the batteries "reappear" but this is not usual and can actually be problematic. (there is history).
You NEED to determine which Cause is creating this issue.
Most often it is the battery packs reaching OVP and cutting off, which of course drops the Inverter and everything attached thereto.
The GOTCHA !
LFP has two Voltage Ranges like ALL BATTERIES DO !
The Allowable range where NO harm is done to the cells is 2.500-3.650 but this is NOT intended to be used daily.
The Working Range which is what Manufacturers test & Validate cells to, and is responsible for delivering the rated AH is 3.000-3.400 with Nominal Voltage being 3.200 (50% SOC).
Far too many People & even Companies try to push that envelope and end up suffering issues, sometimes with terrible consequences.
A Moderate & Reasonable Charge profile that does not push cells beyond working voltages will prevent OVP/UVP conditions and keep you happily running for years.
SETTING | V per cell | 12V | 24V | 48V | notes |
Bulk / Absorb: (boost) | 3.425 | 13.8 | 27.6 | 55.2 | Absorb < 60min Transitions to Float |
Equalize: | 0 | | | | NOT for Lithium Based Batteries |
Float | 3.437 | 13.75 | 27.5 | 55.0 | allows cells to balance internally |
Min Volts: | 2.650 | 10.6 | 21.2 | 42.4 | Never allow to drop too low. Safe Buffer |
Max Volts: | 3.575 | 14.3 | 28.6 | 57.2 | |
Rebulk Voltage: | 3.200 | 12.8 | 25.6 | 21.2 | |
End Amps / Tail-Current: | | | | | formula: 100AH X 0.05 = 5A |
