Anvilsbeme
- Jan 11, 2020
- 17
The following question relates to a grid tie solar system without battery storage. See attached simplified line diagram if this helps.
Is it possible to connect three 4000 watt inverters (SMA Sunny Boy 4000US) in parallel instead of using one 12kW inverter.
Thanks in advance for your replies. I'll check back in the evenings in case it takes awhile to answer any questions that gets generated.
