If I had an independent solar/battery/inverter system already set up and wanted to connect it safely to my grid breaker box, how much would just those parts cost in Australia?
But in answer to this cost question, it will depend of the specific requirements of the home.
But I will give our specific example which cost A$600, or about $US440 (supply and fit by licensed electrician).
We have an 11kW grid tied solar PV system. But occasionally we have grid outages and having backup is important to us.
So I had an electrician supply and fit a power inlet and "break before make" transfer switch so I could connect a generator to provide power the house. This isolates the off-grid power supply and backed up circuits from the grid.
Because my home is 3-phase power it required a 3-phase transfer switch but wired in such a way that the essential circuits being backed up could be joined on a single phase
while operating on backup. No 3-phase appliance is included on the backup supply.
The cost of having a licensed electrician supply install the power inlet and the 3-phase transfer switch was A$600, or about $US440. Here such work must be done by a licensed electrician, so their time (licence, expertise etc) is the largest cost component.
Since then I have replaced the generator with an off-grid 2.2kW solar PV system, 18kWh battery + AIO inverter. Solar PV keep the batteries on float ready for backup duties, as well as runs some loads, mostly the pool pump during the day plus sundry electronics 24x7.
Because the power is supplied via a plug in power inlet, the off-grid system can be removed and just the power inlet and transfer switch left in situ - any new occupant can use the power inlet to connect their own backup power source. Not that we have any plans to move, but the off-grid system can be pulled down pretty quickly if needed. 6 panels on the garage roof and the batteries, AIO and sundry cabling, fuses/breakers etc can be pulled out pretty quickly.
We had a 4-hour grid outage last week - a massive rain event caused havoc. We were fortunate to escape the worst (lots of devastation here, a hundred thousand were evacuated) but I have friends to the south who will be without power for at least a week. Flipped the transfer switch and we were operating on backup. I may at some point replace the manual transfer switch with an automated version. I can redeploy the manual switch to the mancave where one day I'll power it via an off-grid system.
