Understood that higher voltage reduces amperage at the same watts. 5amps at 20v=100 watts ~ 1amp at 100v=100 watts .Also understood that higher voltage suffers less loss for a given size of conductor which allows for longer runs. Thus for transmission the higher the voltage better.
However when the SCC must convert this voltage to a proper voltage for battery charging is it better to be closer to battery voltage range or does it matter at all?
Thanks for your input.
