NorthTown2022
So I am currently monitoring a new inverter and 14kwh battery (with a JBD 200A BMS installed) remotely. I am experiencing some strange voltage drops on time based intervals. Readings are affected on both Quatto and shunt. The readings go back to normal after toggling the inverter 'on' from either 'off' or 'charge only' setting. Here is a clip of what's been going on over the past few days. It happens consistently every 1097minutes. Any thoughts?
