B13Z
Hi guys, I have just replaced a failed bms with a JBD 7s-14s 30A bms. I can connect to fine via Bluetooth but it will not discharge. It only outputs 7.96V.
I have a 10S configuration. The wiring diagram says to connect the remaining bms cell wires up to the 14S all to the 10S cell. For some reason I am getting micro voltages on cells 13 and 14 when really they should be zeros like 11 and 12.
There is also 2 solder points on the board for a switch which I have bridged but it doesn't seem to do anything. Also, everytime I turn on the discharges switch it resets back to off.
Do I need to set anything up on PC through the UART connection? This is doing my head in and I'm struggling to find any information that may help.
Any assistance or suggestions would be greatly appreciated!
![1000010065.jpg 1000010065.jpg](https://diysolarforum.com/data/attachments/223/223748-ed567291a887a8160083c3966a0b2f45.jpg)
![1000010063.jpg 1000010063.jpg](https://diysolarforum.com/data/attachments/223/223756-d2816b12c1c4626479737b6436f9ad76.jpg)
![1000010064.jpg 1000010064.jpg](https://diysolarforum.com/data/attachments/223/223750-24a43a135b94f4176431c679d36e046e.jpg)
![1000010066.jpg 1000010066.jpg](https://diysolarforum.com/data/attachments/223/223751-19c3e64d04f67d9a2300779f41931760.jpg)
![1000010068.jpg 1000010068.jpg](https://diysolarforum.com/data/attachments/223/223753-af2ce83fef988a77db4b94cd07e7f9fe.jpg)
![1000010067.jpg 1000010067.jpg](https://diysolarforum.com/data/attachments/223/223758-5581e96d1909f10bba1ba02d0500d813.jpg)
![1000010069.jpg 1000010069.jpg](https://diysolarforum.com/data/attachments/223/223759-a2e16909ba050e852b8fc01596e6f5d2.jpg)
