Jeep/ATV winch for Elevator? What do you think?
Thanks for posting that! The big issue I see with that system is that there's no backup for a cable or motor failure. Otherwise it's pretty close to what I was thinking, although I'd still want 12V just for power outages.
The original system I was thinking about had two motors/cables so that if either one failed the system wouldn't fail. I was thinking bigger wheels in a track, that way a "wheel chock" sprung from cable tension could be used as an emergency brake. But, didn't like that she'd be stuck in the elevator in an emergency, and wasn't sure if two hoists would work in tandem (need to research them more). Also if one failed and the cable got stuck, the second one would keep you from falling, but you'd still be trapped (possibly able to go up).
Both @Rider and @HRTKD reported problems with winches (one very unexpected from a tier one manufacturer). I was wondering if hoists had the same problems or not and at 18:30 he talks about the cable strands rolling over each other causing the elevator to shudder. Possibly a higher quality hoist might have a better guide to eliminate that? But even so, will they pull in tandem? What happens if one fails, how do you get out?
Hard to beat the screw-driven system for safety. Seems like it would work with and inexpensive electric motor (cheaper than a hoist/winch anyway), although a long threaded rod will easily make up the difference. What I'm not sure about is how you'd keep the threaded rod lubed and clean. Also, how do you escape the elevator if the motor fails?
@BiduleOhm also talked about a worm-drive, which I believe he meant to be the same as a screw-driven, but it sparked an idea of using a short screw to turn a cog that operated the lift -- seems like it would have all the safety and even less cost. But what I really like about the cog is that there's no cables to foul the system from going down (that is a hand-crank with a prawl could be used to lower the system for emergencies by disengaging the screw). Downside is I don't know of ready-made parts that could be reused for that (more research ;-).
Update: Turns out the brakes on some hoists work via cable friction and the #1 cause of brake failure is a contamination on the cable (grease/water). Given this would be outside with rain and squishy bugs...not a good idea. A hoist would need to have an alternative brake (e.g., brake drum) or gearing mechanism that insures no slippage (e.g., worm drive).
A friend of mine uses a 2000lb atv winch on a homebuilt crane to lift engines out of cars and other various heavy things. It might not be the best thing for the job but it works okay.
Been looking more into the worm-gear cog idea. Turns out gears and gear racks aren't hard to find. I first ran across bicycle cogs, using bicycle parts is an interesting idea as the wear on a bicycle chain would be reduced since the chain wouldn't move in this application. But strength and quality would be iffy (sure you could double up or get an industrial roller chain, but a gear rack should be less expensive and stronger).
Gears and racks also led me to the video below. I don't think it would work unless you could find a heavy duty industrial screw-drive version. Might otherwise might not be as crazy as it sounds. The screw drive would prevent catastrophic failure, could use the light sensor to detect obstructions in the "pit", they have load sensors to detect if there's too much weight, radio remote controllers (one at the bottom, one in the cab, one at the top)? But a regular one just wouldn't be strong enough (weight of the cab + people + stuff + safety margin). Still have the problem with a trapped occupant, it would be nice if they could manually lower the car.
Update: No modern garage door opener will work for the purpose. Turns out they all have force sensors and if the the load isn't the normal amount it stops, Obviously in any sort of a lift the load will vary a lot (from an empty car to one with stuff)
... [eddie currents are ] a very very elegant solution for a lot of reasons ;) but the problem is cost in magnets and copper...
So, I couldn't just superglue $20 worth of pennies and the magnets off the fridge?
Well shoot... I do like the idea of detaching the cable to do a safe emergency descent if you're otherwise stuck.
You could have one of those detach pulls like you see on garage door openers to manually open the garage door. ;-)
Aluminum should still work and is 1/4 the cost ... although you'd probably need twice as much (wonder if there are any new super cheap high conductivity sheet-like materials, some sort of Graphene?). Pity silver is so expensive. As for the magnet... how about an electro-magnet? Not sure how you'd reliably automatically trigger it during an unintended descent (a mechanical acceleration switch?) so it would be fail-safe (brakes generally work the other way, that is the break is on when there's no current).
At least it is only a 6 or 7 foot drop when it fails.
She'd probably be sensitive about that. Preferably we could figure out something to reduce the amount of freefall.
As you're stating, an elevator brake works the other way, and for a good reason... --> safety, as always ^^
An electromagnet wouldn't be safe enough to me, you need permanent magnet(s).
Saw an interesting DIY elevator where they used a fall arrestor as a secondary safety mechanism (like a centrifugal clutch or seat belt). The follow-up had a number of changes suggested by viewers and was interesting. Found you can also get them with a rip-cord, to allow a slow descent which I really like as you won't be trapped in a suspended elevator.
While cool, did a little looking into the fall arrestors, and they're pretty brutal, a class A takes 24" to fall -- so a two foot drop. Although in the videos it's like three inches... so hmmm.
These were really cool, the left is a Roller Screw and the right is a Ball Screw, both translate over 90% of the turning energy into linear motion.
If we looking at cool actuators I must include helical band actuators
Unfortunately I have not found a site that lists their prices.
How attached to the house is she?
Swap her home out for a single story one with no stairs. Or apartment/home/unit/something with a lift in the building already.
Sure, just throw common sense out there. ;-)
Her stuff just arrived at the new house (the one that could use an elevator) Sunday and we've been unboxing / assembling this week, bad planning I know. Just assumed an elevator would be a reasonable cost. Considering how traumatic this move has been, I doubt she has another one in her.
You know how your IQ goes down as you get more tired? I'm a poster for it. I'm a mess of minor injuries, all of them stupid that happened long after I was ready to quit for the day (e.g., cut the rivets out of the "security gate" in the mailbox (too hard for her to operate) and burned my fingers on (you guessed it) a hot rivet).
I was looking at a commercial system to see what they did for the main safety feature. Surprised to see it was like a garage door, that is two wires (one on each side) suspend the car from a single shaft. No springs, the motor was worm-gear driven so no slippage and if one cable breaks the other can hold the whole load. Couldn't tell, but it probably had drum brakes too. Interestingly, the drums the wire cables wrapped around were grooved so they wouldn't overlap like you'd see in a hoist/winch (which was reported to be a problem in one of the videos). Also had a hefty diameter (4"), so each turn would be about a foot of lift and 8 or so winds.
Update: looking as the ASME requirements for lifts, some interesting things in here. The drum mentioned above being grooved... mandatory for "ropes" (5.3.16). Looks like two cables on a single shaft is okay too.
FWIW My brother and I got one of these for my mother after she had a stroke.
My dad is still kicking at 93 ( WW II vet ) he uses it for laundry hauling laundry
Up and down the stairs, theirs is an interior model but the outdoor one looks the same.
Pretty simple installation, lag bolts into the tread. 110 v wall plug, I can't remember but I'm
Pretty sure it has an internal battery for power failures. My guess is the most expensive
Part of this is the liability insurance.
Load Arrestors
You can get load arrestors that will stop the fall of 500 kg at speeds as low as .3m/s and they have some shock-protection. Let's say the lift speed is such it takes 30s to go 8 feet (what one of the videos reported as "comfortable"), so that's .08 m/s, slow enough it won't trip the arrestor.
If the cable broke, how far would you fall before exceeding .3m/s? From the splat calculator at freefall, that's under a 1/4", that's not bad. At .5 m/s that's about a 1/2 inch.
For anything DIY something like this attached at the top to something solid other than the frame (e.g., deck) is probably mandatory as the mother of all backups. The ASME has a lot of other really good ideas regarding additional safety features, well worth reading (some obvious, some not-so-obvious) as you might expect from years of analyzing failures.
