Thanks, assumed incorrectly it would start a charge cycle.If this switch is turned "ON" it prevents from going into Float mode after absorbing - the charge mode stays on bulk then
Who's battery setup?I remember looking at this battery setup and thinking oh heck that is a dangerous mess, sorry gonna call it as I see it.
After reflash no CAN disconnects but now the inverter is stuck in bulk charge. BMS hit 100% quite a while ago and force charge is off. It’s just pulling and pushing a few amps from/into the battery and holding. Any areas to look at?
Yeah. Been balancing for a while. Delta is .048 now which is highest I’ve seen it for a while.how is the actual cell deviation and is the BMS actually balancing?
Charge status should state 'Balancing' - only once the cell delta drops below the delta set in the BMS will charging finish.Yeah. Been balancing for a while. Delta is .048 now which is highest I’ve seen it for a while.
Yep, anything over 0.005v and it'll keep going.Ahh so so that’s why. It’s been balancing for seven hours. So my delta set point is .005, it will need to drop below that?
Yes look at the chart I posted in my edit above. Slowly coming down.Yep, anything over 0.005v and it'll keep going.
I've set my delta to 0.010v for this reason as any lower isn't required as far as I'm concerned.
Is your delta decreasing over the seven hours?
Just so I’m clear, this is the Balance Trigger Voltage in the BMS settings, no where else correct?Yes look at the chart I posted in my edit above. Slowly coming down.
Yes, that's correct.Just so I’m clear, this is the Balance Trigger Voltage in the BMS settings, no where else correct?
Using @Sleeper85 code I guess.how is the actual cell deviation and is the BMS actually balancing?
are you on version 1.17.3 or 1.17.4?
I'd be VERY interested if you could port the latest changes into your code @Der_Hannes .i might also play a bit around, but I'm a complete esphome noob![]()
I guess I'll test your current version this weekend then. I guess the Deye inverter will trip when I change battery mode from voltage mode to lithium (00 type I assume ?)already working on catching up to 1.17.4 - but have to solve some issues and can´s actually say when it will be finished
I am not particularly happy with some ppl on this thread - not mentioning names , bcos i dont want to give them excuse to start something bcos if they do i might explode on them.That seems like the "offset" / voltage measurement error problem I had.
If it was 0.033V for the entire pack I would understand.
But 0.46V difference across your 14s is more likely a lack of calibration of your jk bms in the jk bms app.
As I said I used to have 0.7V voltage difference for the full pack. First I thought it was a diode. Then it was probably a voltage measurement error. Finally, at NO LOAD, disconnect everything and measure with the multimeter. The difference was there.
Since I calibrated the voltage at NO LOAD in the jk bms app the voltage readings *for the entire PACK* have stayed between +0 ... + 0.15V (instead of +0.7V !).
When I load the battery a bit (especially DISCHARGE) the difference becomes virtually zero.
Good to hear you found and resolved an issue, are your cables also rated for 100A?I am not particularly happy with some ppl on this thread - not mentioning names , bcos i dont want to give them excuse to start something bcos if they do i might explode on them.
But for the project sake and for the sake of ppl who will refer to similar senario when they do their reseach i am updating my findings .
It is not the Pylon protocol causing issues rather it was a faulty fuse when i duge more into the connections.
i have since installed 100A fuses into the individual batteries and replace the fuse with a junction box - and now its all good.
thanks to all those who contributed..
Good luck with future updates......
It's not finalised yet, we're doing some internal testing first to make sure nothing blows up.I’m using 1.17.3. Balancing is almost complete. Down to .012. Trigger is set to .010.
I didn’t know 1.17.4 was out. Don’t see it on git.
No, mine does not trip - trips only when changing grid mode, low noise mode or something relatedI guess I'll test your current version this weekend then. I guess the Deye inverter will trip when I change battery mode from voltage mode to lithium (00 type I assume ?)
Oh wait, mine is grid connected - maybe it trips when you are off-grid? I don't know thatNo, mine does not trip - trips only when changing grid mode, low noise mode or something related
