schreib69
Trying to solarize my Lane sensor, presently it runs for about six months on 4 little 3 volt Li Ion batteries. I converted it to a much larger AGM battery with a Schumacher brand, solar battery charger. Not sure if I screwed it up by the way I installed it but I am having to bring the battery in every few months from down the road and charge it fully; stopped using the solar thing because it appears to do no good. I have a few things I simply do not understand about the unit and what to expect of it. Regardless, I am abandoning this solar unit and have concluded I really need to include a charge controller(not sure it has one on this cheap little thing).
So, initially, I am considering a 30 to 50 watt x 12 volt solar cell with a mating charge controller. Plan to buy a battery designed to mate with these. Looking for suggestions as to models, brands, or if I am totally off base and heading into the wilderness. . . THANKS!
Lane sensor: Magnetic field sensor 12" under the road, senses change in magnetic field when engine passes over it; relay sends a radio signal to an antenna 1/2 mile from the house; house receives it and voices an alarm: "Alert zone one!" So, the energy used to operate this only happens when a car rolls over the sensor on the road. If so, the energy is used to operate a low voltage circuit and pull in a 12 volt realy for a few seconds. Not much to power here. Why Solar? I don't like to go out in the middle of a -20°F winter to change batteries.
