My RV has a space for 2 100ah batteries on a frame - I don see anyone using DIY battery build that fits directly into existing battery case.
This is bumper pull, no garage space and very limited space inside to build all batteries, inverters etc. I don’t want to go with drop in 100ah replacement as 2 100ah is not enough. Need minimum 450ah (600ah recommended) per calculation spreadsheet.
Couple of questions:
- Any reason why not to keep lifepo4 batteries outside on a frame in existing boxes(Not camping in freezing temps, only storage is in freezing weather)
- Summer time temps can go to 100F, would EVE LIFEPO4 batteries be severely affected in heat?
- What is largest ah capacity that can fit into standard AGM deep cycle battery case - (12v 100ah is too small)
- Anyone is aware of someone making a case that would fit 8 “EVE LF304 304Ah 320Ah 3.2V LiFePO4 Prismatic” that could be mounted where the 2 batteries currently are located and exposed to elements? I would install BMS inside case too.
