I would like the thoughts of the knowledgeable here, I've recently fitted a drop in LiFepo4 120 A/H battery to my caravan and was wondering during the times we aren't using the van whether it would be better leave the battery connected with solar (on float) or disconnect the battery completely.
The LiFepo4 manufacturer says it is a true drop in battery and that it is OK but I've read so much on the no no's of keeping LiFepo4 batteries fully charged or on float when storing as it is said it can reduce the life of the batteries considerably.
I have an isolator on the solar panels that can be turned off but there will be a small parasitic drain (approx 150mA) if I leave the battery connected.
What do you reckon?
Scotty
What do you reckon?
Scotty
