FrugalNomad
- Jan 15, 2021
- 4
Hello DIY Solar Forum,
This is my first post to the forum. I am putting together my first "system", but just the start of one, that hopefully will expand as my vehicle changes over time. I have searched for this minimum voltage for MPPT, and found some posts that make it sound like I need at least 17 volts to use MPPT to Lithium. Is that 17 volts Open circuit, or Max Power voltage?
Currently traveling in a Prius, and want to power a small 12VDC compressor fridge, and maybe some other devices from time to time. So, after mulling over the options, I decided to err on the side of safety, and ordered a Battle-Born 12V 100ah. My water jugs never freeze, so I doubt I will have a cold charging problem.
I found a Lensun 110watt 18V flexible ETFE on amazon that is the perfect size for mounting on the back hatch glass. The only problem is it said 18V on amazon, but 16V on the panel label:
Amazon Electrical Information:
Peak Power: 110W
Solar cell efficiency 23%
Maximum power voltage: 18v
Maximum power current: 6.11A
Open Circuit voltage: 21.24V
Short Circuit current: 6.72A
Power allowance range: +/- 3%
Maximum system voltage: 500V
Panel Label:
Model LS-110FX2-SUN
Pm: 110W
Vpm: 16V
Imp: 6.88
Voc: 18.88
Isc: 7.56A
Max System Voltage: 500V
Test Condition: AM=1.5, E=1000W/m Tc=25 Deg.C
This must be a different panel. On a grey overcast afternoon in SC, it measured 17.14VDC open circuit. I don't yet have a charge controller, but was hoping to go MPPT, and allow for adding another smaller panel in parallel, possibly in the future. But I'm thinking this will not work for MPPT to BB LiFePo4 at such a low voltage. I have free returns on amazon prime, so, considering returning for a different option (maybe two smaller panels in series). Or would it make more sense to just get a good PWM, and then expand with a solar suitcase with another charge controller if my needs increase?
My other concern is that I have no way of testing the panel until I get a controller, and one post on Lensun recently has made me start to doubt that it is a good choice.
Cheers,
FrugalNomad
Peak Power: 110W
Panel Label:
Model LS-110FX2-SUN
Pm: 110W
Vpm: 16V
Imp: 6.88
Voc: 18.88
Isc: 7.56A
Cheers,
FrugalNomad
