Refinished
Shocked and Amused
In cells that are getting mild bellies, what gas is being produced? Are the vents usually designed to do an as-needed release to keep the pressure under some spec pressure or are they one-time plugs that blow out? Are there generally obvious signs that the valves have released something? No need for Replace Or Die responses - I'm interested in the above answers from a chemistry and engineering PoV. Thanks!
