I am planning to put together 4 Calb CA100 cells in a watertight box with BMS for powering a Minn Kota 55lb thrust outboard. The only charging will be from a DC-DC Victron and I will probably add solar to the system. Max current out will be 50 amps and charging not over 30 amps. Common port is all that is needed.
All the Daly LiFePo4 BMS I can find are 3.75 volt charge cutoff and 2.2 volt discharge cutoff. I would like to find a BMS with 2.5 volt and 3.65 volt settings.
The simpler the better, and not expensive.
I am using the Electrodacus for the 400 AH system on the mother boat.
Any ideas?
Any ideas?
