pralinebuckets
- Jan 3, 2021
- 59
Hi all,
I'm not sure if I'm reading this right so I'm hoping someone can reassure me.
I have a fully off grid site without solar.
I have a ~10000W generator with a 240V US output that I would like to use as the charging source for lifepo4 batteries.
The specs of the LVX6048WP are here: https://www.mppsolar.com/v3/catalogs/LVX6048WP.pdf
They state that the AC input can be 50/60Hz and 120/240V
Linked on the product page is this generator requirements doc: https://www.mppsolar.com/v3/catalogs/generator requirement.pdf
It states the following:
*below is for 220-240v European single phase type; North American 120v is marked in black
For European 240V Systems:
Vrms range: 100 ~ 270Vac
For North American 120V Systems:
Vrms range: 65 ~ 140Vac
There is overlap of the voltage range on the Euopean 240V spec that would cover the USA 240V spec, but since I'm about to drop a lot of money on this thing I'm tweaking on the omission. This unit will work with a USA 240V generator, right?
