You could always crimp a 6" length of 10 gauge wire into the mc4, then use a larger splice on the other end of the 6" 10 gauge that would accommodate the 8 gauge. Just crimp down real good on the 10 gauge end of the splice. A standard electrical crimp tool available in the electrical section should work just fine. Use good quality waterproof heatshrink tubing and viola!Im considering going with 8AWG PV to SCC wires instead of 10AWG. But all of the crimping tools and MC4 connectors only go up to 10AWG. How are you'all making your 8AWG wires?
Available at building supply stores.If you can wait a month,
Enclosure Waterproof Case Electrical Junction Box Connector Terminal Wire Cable | eBay
Waterproof Junction Box only, other accessories demo in the picture is not included. 1 Set x Waterproof Junction Box. Supporting connector: 3 PG9 waterproof connector with a gasket. Better fixed cover.www.ebay.com
If you want one in a week,
Waterproof 3-port electrical junction box PG11 strain relief 3-way wire circuit | eBay
Find many great new & used options and get the best deals for Waterproof 3-port electrical junction box PG11 strain relief 3-way wire circuit at the best online prices at eBay! Free shipping for many products!www.ebay.com
The strain relief/water stopper is called a 'Cable Gland', all number of wires, all shapes wire comes in.
Romex oval, Google 'Oval Cable Gland' and this pops up, what I like to use for tinned marine wire with a jacket, looks like Romex but with only two conductors in the jacket.
Makes for a tidy install.
And breakers, midget fuse blocks, buses, lugs, mc4 connectors.... balance of system parts are integration parts. The glamour goes to magic boxes but they have to be integrated into projects and bos trinketry hoards are essential to tinkerers!@JeepHammer
4.50$! With strain relief fittings and a terminal block....
Thats a budget saver for small projects.
The strain relief fittings i use from heyco, 2- hole pv wire and 3, 4, 5 amd single hole in 1/2" and 3/4" k/o start at 4$! Each.....
I take it for granted to have organizer totes full of them.....and din mount terminal blocks.
Done!
Temporary combiner.... some friends lived here in a couple pop up campers from may to october. We threw this up as a hasty power supply.
People think im kidding about kombucha combiners rated "kernel 3R"
I was going to do the same and go with 8 AWG but WP advice against it. But everything else I overgauge keep short as per WP.Making 8AWG wires with MC4 connectors is not something anyone does....ok, and after searching combiner boxes it looks like they are used in larger systems, ( I'm only looking at 4 100w 2s2p on my RV roof ) , maybe I dont need 8AWG.....its just a long wire run. thnx for the reply cass !!!
I do everything you do right down to the pull string, bravo!I see it all the time, but I don't get the call unless something ISN'T working.
$2,000 in batteries, $100 in cable...10¢ exposed terminal ends...
100A through a 20A crimp terminal, not something I do, but some people do it...
Waterproof inline fuses holders are $4 each, fit in the terminal box on the back of the panel, but you can't make anyone put one on a panel/string even at gunpoint.
A couple of guys on this forum keep saying fuses will CAUSE arc over and burn the house down... What can you do with that?
Something to stop corrosion, like a $6 tube of dielectric grease or Oxiguard, guys on here tell newbies it will prevent electrical contact and/or burn the house down.
*I* (Personally) solder a lot of my terminals, hard crimp, proper electrical solder, glue filled heat shrink, done.
Mechanical connection, electrical connection with environmental seal, another environmental seal and electrical insulation I know isn't coming off, slather screw terminals in grease or sealer.
I built to last 20 years, I'm over the 20 year mark and doing the first big upgrade.
Not because things are failing, everything still works, but because solar panels aren't buy and forget, they do have to be replaced every 20 years or so because they degrade over time.
I look at DIY as a way to do the details, those little 'Jet' torches make soldering stupid easy on bigger terminal ends, and for DC it's a big help, and 'Waterproof' isn't, where solder or grease is water can't be, humidity can't condense or enter wires/cables where grease/solder is...
I'm not on a 'Clock' so DIY let's me do the details, and the devil is in the details.
20-ish years on about everything, so far every screw has come out the way it went in, my wiring is in plenty good shape to reuse, so the upgrade is going slow but it's progressing OK...
It's like adding a string to the wiring in conduit...
A string hurts nothing, but when you want to expand, add more wires, it's unbelievably handy!
PULLING a rope works MUCH better than trying to PUSH a rope...
Oh look it's a Kombiner!Done!
