So, beginners question here. I purchased eight 304 AH Eve cells, Which are wired up in series for a 24 volt system. The BMS is I believe the same brand that Overkill solar sells.
I initially top balanced the entire pack in parallel up to about 3.58 volts. All good.
When I go to charge the pack it seems to cut off right around 3.4 volts per cell, which seems on the low side. I bumped up the maximum voltage to 3.65, with an over voltage protection I believe of 3.9 in the BMS. Didn't seem to make a difference at all. Still cuts off at about 3.4 volts. Cell voltage differential is .010
I guess this is great in one sense that the BMS is not allowing over charging, but would still like to get the volts up to around 3.5, yet I'm at a loss to explain why the I can't get any higher than 3.4.
I've gone through all the parameters settings in the BMS multiple times, and it doesn't seem like I'm missing anything, but I'm posting here in the novice section so I am certainly no pro at this. Could anyone give me any guidelines as to what to try next? My understanding is I should be able to safely go up to 3.65 volts per cell, although I would get a longer life if I went lower. Somewhere in the 3.5 range is what I'm shooting for.
Thanks,
Troy
Thanks,
Troy
