Anderson connectors are not water tight. They make caps and boots so you can wrap up the kiddies, but in weather water would get in and corroded things.
I am not disagreeing with your overall concepts , but the Andersons are a pretty good quick connect if installed properly ..the rest of your examples I have no opinion on… but 8m sure they have their place in the world
I have used andersons for decades , for many reasons ,many times from boats to snow plows to my solar wire runs from the panels to the equipment location I am using them on and the 4 new arrays new ones I am building now…
There are se real kinds but I’m speaking of the standard Anderson ,stout , 2 pole push in connector about 2” wide and long…I get them from PowerWx …
They make a great stable connection and easy quick connect ….
They were NEVER meant to be water proof ( but reasonably water resistant if installed correctly) ..
If they are just hooked up and dangling in the rain or wheel splatter of a salt truck or boat trailer , sure they will get messed up… incorrect installs is a giant cause of many good components in life..maybe the biggest problem there is in DIY …
I have rubber caps and boots for mine of two designs but only use the end cover types for electric safty..not so much for water protection as the connections are always terminated and live in a waterproof junction box ..with a gasketed door ..it never has any water inside …other than ambient humidity.
They alway should be installed in a decently protected environment . If done that way it will probably exceed it “disconnect cycle life” before it ever fails due to water or anything else.
The ones on my last snow plow lasted the full 10 years of service on my truck ( then I sold it) I used no special install tricks except make the mating connection inside the truck engine compartment up high…
protected from the water and salt crap…
I have never seen a properly made up and maintained one corrode ( if the lugs were crimped properly , and heat shrinked properly …and mounted in a safe place
As far as corrosion the contacts that mate to connect are self cleaning with a special textured silver finish over the copper connectors when connected or disconnected ..there is alway a fresh new clean surface area path if you look down inside the fitting after a few uses.
Someone has to doing something wrong to have corroded or flooded out Anderson in a reasonably typical environment…. If you didn’t want to have a quick connect or disconnect feature it would be silly to even use them…
Any one considering them should always remember ( unless somthing has recently changed)
the SB 175/series are the only anderson connector that can “reduce or step up” the wire size between 6ga and 1/0 awg on the same fitting.
Thst is a huge help when joining two size wires for different needs or long runs…
( for example ) you order the 175 6ga side and it will mate properly with the 175 2ga side or 1/0 or 4 ga or whatever side . Each side has different ferrels but will still mate together ..
.I use a 6 ga set up from my combiner box that steps up to a long 1/0 pv run ,( yes ,far to large) then steps down to 2 ga to hook up the wire to the Victron 150/100 on that particular array.
The outvsides are identical but the insides are made for locking in different internal ferrels ..the regular ones only accommodate one size wire for both sides of the connection..
There are no perfect connection I have found , just different ones for different purposes…
I don’t have any but it seems they make a 3 pole version for people wanting 3 wires on each run…
I love mine…they will certainly out live me and my gear…
J.
