Hey, I’ve installed a new solar bank, I have 12 290w panel. I decided to go with micro inverters. First time, my other two banks are string, anyway….I have 3 inverters, four panels on each. The inverter is 1200w to 110v. I have each inverter on a separate circuit. Heres my issue. the max power I have generated is 550 w. At noon in full sun., electrician verified my connection and panel output. The inverter just won’t produce. I have only one idea (it’s been around 110f the past two months) maybe heat is affecting its? If any have some suggestions pleas interject. Thanks!
