NaughtGeek
- Oct 7, 2021
- 10
I had to replace 2 cells in my 16S4P system. Since they were new, their SOC was off from the bank they're in. I charged the entire system and then discharged until the new cells hit the low voltage cutoff (2.5) Now I'm changing the entire pack at 40A (10A per bank) 52.6V(3.29 x 16) to slowly bring the SOC back up. Is there anything more/better I can do to bring these 2 cells in line with the rest of the system or if I just leave it once the inverters feel the pack is charged will they eventually even put? I don't have panels yet so this is only serving as a UPS for my house. I have a Batrium BMS but once charging stops I don't know (understand) if the bypass function will do the job.
4 MPP Solar LV6548
64 EVE 304AH cells 16S4P
Batrium Watchmon Core with 4 Cellmon K9s
Solar Assistant for Comms With Home Assistant
4 MPP Solar LV6548
