I use VHB tape often in our shop, just not for holding down tracks for solar panels on the roof of a moving vehicle. One use for this tape is to hold glass panels onto skyscrapers, so I don't doubt its adhesive properties. I would even grudgingly accept the notion of using fewer fasteners with VHB tape applied along the entire length of the rail and two end fasteners and a middle, but why take the chance of one or more panels coming off the roof and into the windshield of the person behind you?
That's why I believe it's f'n stupid. And I won't do it when customers ask. 75% of the time, once I show them the Merlin panels, show them the installation on the slideout of my personal RV, and tell them the labor cost is far lower to install them with no extra roof penetrations, they agree to try them. In the last 18 months, I've only had one fail and it was due to poor quality seam sealing tape. Once we switched to using 2" Eternabond we've had no failures.
I installed glass panels on the roof of my personal rig three years ago. I installed the Merlin panels on the roof of the slide earlier this year. Their form factor is very low and easily slide under the bulb seal. I used two TBS180L panels in series. We ran the wires along the same cable management device under the slide with the other wires to a separate solar charge controller. The extra 300ish watts covers most of the energy budget for my mini-split A/C. Every watt helps
P.S. The heating issues of other flexible panels are well known and I can vouch to it. I had at the time what I thought were the best flex panels I could find, the Sunpower flex panels with the Maxeon cells. They performed well but I only used them as makeshift solar window awnings. About two years ago I came across Merlin Solar when doing some research. I even got to speak with the inventor of the technology and current CEO. They sent me data from Intertek proving the durability in wind testing and partial cell shading that causes hot spots for other manufacturers. He convinced me to give them a try so I ordered a few units to install and test. The panels were purposely designed to be used on curved, flat, commercial, membrane roofs.
We now use them on all of our mobile builds, including commercial builds, unless a customer absolutely must use glass panels.
I'm not selling anything to anyone here on this forum. I'm just giving you my professional experiences with this product.
