Hi im from philippines.. Im planning to set up this MPP all in one solar panel box.. What unit you can recommend because in my country we are using 220 volts and 60 hz.. Thanks..
It depends on your needs, how many whats will you be using out of it, they usually recommend the 3Kva unit that is 24V and you need to make sure that the unit says 220-240Vac
